We are using eM Client and connect to Exchange Server 2010 via EWS. But we cannot recover e-mail when deleted accidently. How to recover deleted email by eM Client ?
Thanks in advance.
Thanks in advance.
Hello Mustafa, not really sure what you’re suggesting if you remove a message using the delete button or key, the message should be moved to your Trash folder on your mail server. If it’s deleted using hard delete (shift+delete) the message is instantly removed from your database as well as the mail server.
If messages were moved to the Trash folder, you can simply restore them there and move them back to Inbox, however once Trash is emptied it is no longer possible to access those emails without a backup of your email data.
