The best way to import contacts from Excel to Android with proper field mapping is to prepare your Excel spreadsheet carefully, ensuring that each column corresponds to a contact field. Convert the file to CSV or vCard format. If using software like MailConverterTools Excel to vCard Converter, you can choose manual or auto mapping during conversion, so Excel columns align correctly with Android contact fields. After importing the resulting vCard file, all contacts display correctly on your phone, without missing or misplaced data.
