How can I tell eMClient to immediately erase the just deleted message(s) and not to move them to “Trash” folder at first?
Peter
Peter
“Shift + Delete”, standard Windows erase combination without trash. P
Ok, that means there is no GUI option which tells eMClient to treat a “delete” as “immediate erase”.
I have always to remember und use a key combination to perform an immediate erase??
Peter
Are messages in “Trash” folder always automatically erased at exit?
there is the option in settings to empty Trash on exit.
Just check the option in Menu>Tools>Settings>General.
