How to disable -- substitution
I’m composing an email, and I need to type exactly -- in the email.
But eM Client always replace -- to
How can I disable this feature as I don’t need it.
Thanks.
It seems this forum does the similar substitution too.
Let me change the wording
I need two - - hyphen-minus - ASCII Code but eM Client replace it into — - em dash - ASCII Code
Try paste it in either Notepad (Windows) or Textmate (Mac) first and then paste that in eM Client and see if that works as a test like as in the below example using V10.3.2412
That only work when there is nothing after --.
--a for example, is not working.
I manually do gpg sign in terminal, then copy the result of clearsign into eM Client.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
test in 20250628
-----BEGIN PGP SIGNATURE-----
xxxxxxx
=tNEV
-----END PGP SIGNATURE-----
Become
-----BEGIN PGP SIGNED MESSAGE——
Hash: SHA256
test in 20250628
-----BEGIN PGP SIGNATURE——
xxxxxxx
=tNEV
And the substitution will break the signature.
