I get this error in a red triangle and cannot get rid of it. I have unchecked the “show operations error” and that did not get rid of it. Please advise
[Google Contacts] Deleting items in folder - - - - [email protected]/Other Contacts’ failed due to the following error: Parameter validation failed for “resourceName” : The value did not match the regular expression ^people/[^/]+$
What version of eM Client do you have ?
Also if you have been trying to delete contacts in the Gmail / Other contacts see my post in the following link.
Cyberzork
I have eMclient 10.1.4588
I went to Google contacts and went under “other contacts” and cleared out allot of those that I didn’t want, I didn’t see anything that referred to perimeter validation failed for resource Name
I then found an old forum post that was dealing with this same error and I went to contacts and selected “repair” but that did not do anything
I am still getting the red triangle with the error listed above: parameter validationfailed for resource name.
Any suggestion would be great
Ok as you have cleared out all your Google other contacts online and also run the Google contacts repair and still have the same problem with the latest eM Client version, then sounds like you have a local Google account problem within eM Client.
So i would next suggest to go to “Menu / Accounts” and remove your Gmail account. Then re-add your Gmail account via the automatic account wizard along the top.
Before removing make a manual backup via “Menu / Backup” incase you have to restore for any reason. You can see when the backup is complete in Show Operations via clicking the dropdown on the right of Refresh top left.
Cyberzork,
For some odd reason when I opened eMclient today the red triangle and the error message is gone?? Perhaps the “gremlin” got tired and went elsewhere or whatever I did and did a shut down overnight and a fresh start was the ticket??! But thank you for responding.
