When I receive an e-mail with an attached picture, and I open that e-mail, then the attached picture is displayed immediately at the end of the e-mail’s body.
Depending on the size of the picture, opening the e-mail can take quite long (e. g. IMAP w/o downloading everything for offline use).
I would prefere NOT to see the attachment within the e-mail’s body.
If i want to view the attachment, I would open it up by myself.
Hi, can you please send me the message exported into .eml file? You can do that by simply drag and dropping the email onto a new message or onto your desktop and later attach the message to a new email.
Also what version of eM Client are you currently using? What version of Internet Explorer do you have currently installed on your computer (can you make sure it’s the latest available version)?
Also do you have this issue with all your messages containing images or just some?
Hi Paul, thanks for the quick reply.
- To which e-mail-adress should I send the “.eml” ?
Programm versions (all up to date):
eM Client: 6.0.20498.0
IE: 11.0.9600.17126
This issue concerns all messages.
Hi again, sorry, send it to [email protected] please.
