How to change Categories Droid Mobile device
If an email arrives in either a wrong Category or you want it always in the Primary Category, then first “press and hold” to select the email.
Then press the “3 vertical dots at the top right” and select “Category” on the dropdown.
Then choose either a different Category or select “No Category” at the bottom if you want it always in your Primary Inbox.
