How to block @.MISSING-HOST-NAME
How to block email FROM sender email adres: @.MISSING-HOST-NAME
Give this a try. Note that you will have to define the folder you want to move the message to…
the suggested “try this” does not working. i cannot make anything work. i get 100s of these a day. i am going to abadon the client if something cannot be done about this.
Hi
I also get alot of emails from
@.MISSING-HOST-NAME.
Did you find a way to block completely?
No I have not, that domain is somehow substituted in eM as it is not in the actual mail header. The actual domain that appears in the header looks to be a random character string from the mail relay. I would suggest whatever logic the client is using to determine that substitution we be given the opportunity in a rule to delete.
I get that using mailbird & outlook also. Tried 3 times with Microsoft Outlook chat to fix it, but it keeps coming. I get 10 emails each day from “****”@.missing-host-name.
Anyone find a solution?
