I currently using eMClient 7.2, and its list of available emojis are very limited (see attachement). I was wondering if there is a way to add more emoji options, or if newer versions include more options by default?
Thank you!
-Davide
Thank you!
-Davide
About 2 years ago we added a lot of new emoticons in version 8, which are also there in the current version, 9.
Perfect! I will go ahead and upgrade then!
I am on version 9 and dont see all those. Here’s what I see.
You need to click on one of the categories to see the emoticons.
The category in your screenshot is the History category, which displays only those you have previously used.
Also if you have Windows 7 or 8, you will need to update to at least Windows 10 “or you won’t see all the emojis in V9” as @Gary posted in the thread below.
(Gary’s post from the following thread)
https://forum.emclient.com/t/em-client-emoticons/70561/26
“With Windows 7 and 8, these new emoticons are not supported due to a limitation in the fonts in the OS”.
Gary for the win!!!
