I am new to eM. I am using it on a MacBook. I don’t want any sound notifications from the app. How can I turn all sounds off?
Thanks
a
Thanks
a
Click “eM Client / Preferences (Settings) / General / Notifications”. Then click the speaker icon next to “Incoming” etc to disable sounds as per the eM Client Documentation link below.
(eM Client windows example below)
The default sounds are creepy. I have tried to disable these multiple times. All indications are the red X over the sound icon on everything. I have hit Apply and Save & Close multple times but the creep sound just keeps playing later when a new message arrives. I am about to delete the creepy .wav file.
You can just replace the sound file with any you prefer, the icon to the very right lets you select your own sound file.
Seems like a hack for such nice software otherwise.
Why is clicking an icon on the right to change the sound file a hack ? How would you like to do it.
Disabling the sound notifications work for me ok in V9 or V10 on PC or Mac.
So if you are disabling the sounds and it’s not working, then try uninstalling the program and if you have Windows “don’t delete the database” on the uninstall wizard. Then reinstall the same or later version of eM Client either from the release history page or Windows Store depending on where you originally installed it from and see if that disables the sound when you click the icons.
The toggles don’t seem to work, at least on a mac. There also isn’t a single switch to mute all sounds, which is really obnoxious considering how many there are. However, there is an easy way to solve the problem, at least on a mac:
I suspect you could do something similar under Windows, but I haven’t tried it.
You’ll have to do this for every update, unless/until they decide to fix the problem. (Hopefully they will fix it, but the age of this thread is not encouraging.)
Just as an FYI, I also am having the same experience on Mac desktop in Aug/2026
