How do I sort my Contacts?
I am trying the latest eM Client, Version 5. I imported my Outlook Contacts using a CSV file. I am unable to find a way to sort the list by Last Name, First Name. Am I missing something?
Open “Custom view” and use a column’s header to sort your contacts. If you right click on a custom header you can add{remove another columns.
OK thanks, got things figured out after reading your answer.
