I am trying to set up a group calendar for the entire company to be able to view, but that I manage.
Hi, this depends on the mail service you’re using. Commonly it’s not supported for most standard services to do this from eM Client, you can check if your service is able to do this from our application by right click the calendar, select properties and Access Control, if it’s grayed out and you’re not able to add users, it’s not supported and you have to create the shared calendar online, but then you can use it in eM Client as standard.
Thank you for understanding, I hope I answered your question,
