Yahoo bulk mail does not show up in the junk smart folder. Treating it separately is annoying but not lethal. However, i Get mail in there that should not be treated as junk. In the junk folder, i have the ability to “move to inbox” with the appropriate options. In bulk, I do not. How can I fix this?
Hi Dan,
this is probably caused by the name of the folder, if you go to Tools > Accounts > Your yahoo account, you can change the default folder settings under the IMAP tab.
Just uncheck the option to detect folder names automatically and type in the exact name for Junk folder (“Bulk Mail”), than you should be able to use the Bulk Mail folder as your junk folder again.
Hope this helps,
Thanks. I’ll give it a try.
