I am using Incredimail and have recently dowloaded eM client. I want to import old messages form Incredimal to eM Client.
Hi, unfortunately direct import from Incredimail is not supported in eM Client, however you should be able to import your data from standard file types such as .eml / .ics / .vcf for email, calendar and contact files, if you’re able to export the data from Incredimail using an export feature.
Hope this helps,
