My C: is full and I need to install on E:
martes 03 noviembre 2020 :: 2148hrs (UTC +01:00)
Hi @hrikevin
It can be done but only if you know how to edit the install routine.
Without the level of knowledge required the easiest thing for you to do would be to resize the partitions on your hard drive.
Skybat
