I have generate free pro key for non comercial use. But there’s no option to put it in program.
Path Help > License does not open any option to write it in.
I have version 7.2.35595.0
In Menu > Help > License , click on the Activate button then enter the key. If the application was activated using another key, first click on Deactivate.
I alredy wrote, that there is no such option i my eMclient, there is no Activate option…
Hi Gary,
Just curious…
OP wrote : “I have generate free pro key for non comercial use.”
Since when does eM client provide a “free pro key” ?
I thought it was either Free or Pro…
Actually you wrote that “Help > License does not open any option”. What you actually meant is that there is no Help > License option. These are two different things.
Thats why I put prtsc, to be clear.
