What incoming/outgoing server settings shall I use for hotmail account
Right now I have pop3.live.com Port 995 Use SSL/TLS if available
Authentication Use Identity credentials
smtp.live.com
Port 25
Server requires authentication
Use identity credentials
Where am I wrong? The Emails are hanging in the outbox.
Can you post the log or screenshot of the error message? One possible cause is the ISP is blocking 3rd parties SMTP server (security reason), that you require to use your ISP’s SMTP server.
