The help on the latest is only giving source code and cannot read. Need help with importing from Spicebird.
since Spicebird is based on Mozilla Thunderbird and eM Client supports import from Thunderbird it will be easy. Just go to C:\Users[YourUsername]\AppData\Roaming\ or if you use XP, go to C:\Document and Settings\YourUsername\Application Data and rename the folder named SpiceBird to Thunderbird. Then use standard eM Client Thunderbird importing feature (menu File->Import…->Import from Thunderbird). That should work for you.
Regards
