I just installed emclient and can’t even find the highlighter. Also, can’t figure out how to make a folder. Thanks in advance for any help.
To create a folder that is a sub-folder of your Inbox, right-click on Inbox and choose New Folder.
Can you explain what the highlighter is and how you use it? Maybe I can suggest a way to accomplish this in eM Client.
When I need to highlight I use the background COLOR selector to change the selected text.
