I tried adding Google Keep as a web widget, so I can at least get to my notes in emclient.
The page does not render correctly. Screenshot attached.
Yes i also found that screen when i tried. However i then enabled the “eM Client RSS” Widget below it and then that enabled the normal Gmail login, but even dragging the eM Client widget right down the page to see (the whole Gmail login page) and / or even then disabling the eM Client RSS feed underneath still wont get past the Gmail email address screen.
Clicking the Next button or Pressing enter does nothing. Sounds like the Google Notes Widget link is just not compatible for the Gmail login part. Be nice to get it to work as you said be great to Integrate Google Keep via the Widget. Maybe a later update in eM Client might fix it.
