I ́ve tried to create a gmx-Konto with smtp using all variations of SSL. But it doesn ́t work on my laptop. On all other of my pc ́s there is no problem sending Mails over the same account.
Hi Wolfgang, are you using eM Client on your other computers as well?
Are you seeing any errors from the application? Can you setup the account at all, or does it get stuck on the initial setup?
What version of eM Client are you currently using?
The problem: There was an “€”-sign in the password. After replacing it, all worked well.
Great, glad that it works, I’ll report this issue to the developers if there’s anything we could improve for future releases.
Thank you for pointing this out to us and if you come across any other issues or questions, let us know, we’ll be happy to help.
I have an issue with GMX too. Strange, i can send and receive emails but i got the pop up that the login isn’t authorised. Do i miss any setting?
