I have tried setting up GMAIL access via the eM Client several times and I get the following when it tries to synchronize the folder. What is really odd is that Thunderbird gives the same issue but Windows 10 Mail (which I do not want to use) works just fine.
10:10:28 AM Online state: changed to online due to NetworkAvailability
10:10:28 AM pansloboda@gmail.com [IMAP] Synchronizing subfolders: For folder pansloboda@gmail.com/
10:10:50 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder list
10:10:50 AM pansloboda@gmail.com [Google Calendar] Synchronizing folder list
10:10:50 AM pansloboda@gmail.com [Google Calendar] Synchronizing folder ‘pansloboda@gmail.com/pansloboda@gmail.com/’
10:11:11 AM pansloboda@gmail.com [IMAP] MailClient.Accounts.ConnectionException: Failed opening connection to server.
10:11:11 AM ()
10:11:11 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)
10:11:11 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Connect(CancellationToken cancellationToken)
10:11:11 AM at MailClient.Protocols.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)
10:11:11 AM at MailClient.Protocols.Imap.ConnectionContext…ctor(ImapAccount account)
10:11:11 AM at MailClient.Protocols.Imap.Synchronizer.SynchronizeFoldersCommand.ExecuteInternal(WorkerStatus status)
10:11:11 AM at MailClient.Protocols.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)
10:11:11 AM at MailClient.Commands.Command.Process(WorkerStatus status)
10:11:11 AM pansloboda@gmail.com [XMPP] MailClient.Accounts.ConnectionException:
10:11:11 AM (A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond [2607:f8b0:400d:c0c::7d]:5223)
10:11:11 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder list
10:11:11 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder ‘pansloboda@gmail.com/Contacts/’
10:12:26 AM pansloboda@gmail.com [IMAP] Synchronizing subfolders: For folder pansloboda@gmail.com/
10:12:26 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder list
10:12:27 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder list
10:12:27 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder ‘pansloboda@gmail.com/Contacts/’
10:12:38 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder list
10:12:38 AM pansloboda@gmail.com [Google Contacts] Synchronizing folder ‘pansloboda@gmail.com/Contacts/’
10:12:45 AM pansloboda@gmail.com [IMAP] MailClient.Accounts.ConnectionException: Unable to read data from the transport connection: A blocking operation was interrupted by a call to WSACancelBlockingCall. —> System.IO.IOException: Unable to read data from the transport connection: A blocking operation was interrupted by a call to WSACancelBlockingCall. —> System.Net.Sockets.SocketException: A blocking operation was interrupted by a call to WSACancelBlockingCall
10:12:45 AM at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
10:12:45 AM at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
10:12:45 AM — End of inner exception stack trace —
10:12:45 AM at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
10:12:45 AM at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
10:12:45 AM at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
10:12:45 AM at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
10:12:45 AM at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
10:12:45 AM at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
10:12:45 AM at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)
10:12:45 AM at MailClient.Imap.Base.Connection.<>c__DisplayClass43_0.b__0()
10:12:45 AM at MailClient.Imap.Base.Connection.Connect(Func1 getStream)<br>10:12:45 AM at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)<br>10:12:45 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)<br>10:12:45 AM --- End of inner exception stack trace ---<br>10:12:45 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)<br>10:12:45 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Connect(CancellationToken cancellationToken)<br>10:12:45 AM at MailClient.Protocols.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)<br>10:12:45 AM at MailClient.Protocols.Imap.ConnectionContext..ctor(ImapAccount account)<br>10:12:45 AM at MailClient.Protocols.Imap.Synchronizer.SynchronizeFoldersCommand.ExecuteInternal(WorkerStatus status)<br>10:12:45 AM at MailClient.Protocols.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)<br>10:12:45 AM at MailClient.Commands.Command.Process(WorkerStatus status)<br>10:12:45 AM <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a> [IMAP] Synchronizing subfolders: For folder <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a>/<br>10:12:45 AM <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a> [Google Contacts] Synchronizing folder list<br>10:12:45 AM <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a> [Google Contacts] Synchronizing folder list<br>10:12:45 AM <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a> [Google Contacts] Synchronizing folder '<a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a>/Contacts/'<br>10:13:06 AM <a href="mailto:pansloboda@gmail.com" rel="nofollow">pansloboda@gmail.com</a> [IMAP] MailClient.Accounts.ConnectionException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host<br>10:13:06 AM at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)<br>10:13:06 AM at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)<br>10:13:06 AM --- End of inner exception stack trace ---<br>10:13:06 AM at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)<br>10:13:06 AM at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)<br>10:13:06 AM at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)<br>10:13:06 AM at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)<br>10:13:06 AM at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)<br>10:13:06 AM at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)<br>10:13:06 AM at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)<br>10:13:06 AM at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)<br>10:13:06 AM at MailClient.Imap.Base.Connection.<>c__DisplayClass43_0.<connect>b__0()<br>10:13:06 AM at MailClient.Imap.Base.Connection.Connect(Func
1 getStream)
10:13:06 AM at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)
10:13:06 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)
10:13:06 AM — End of inner exception stack trace —
10:13:06 AM at MailClient.Protocols.Imap.ConnectionPoolEntry.Connect(CancellationToken cancellationToken)
10:13:06 AM at MailClient.Protocols.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)
10:13:06 AM at MailClient.Protocols.Imap.ConnectionContext…ctor(ImapAccount account)
10:13:06 AM at MailClient.Protocols.Imap.Synchronizer.SynchronizeFoldersCommand.ExecuteInternal(WorkerStatus status)
10:13:06 AM at MailClient.Protocols.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)
10:13:06 AM at MailClient.Commands.Command.Process(WorkerStatus status)
