Gmail Sync errors using Nord VPN
After using both programs for years, this week I can only sync if I pause my Nord VPN. Anyone else have this issue? I have reached out to Nord as well. Thanks!
Unfortunately VPN’s can sometimes block mail clients due to the nature of how they work.
So if you have already configured NordVPN to allow eM Client (via the Nord VPN Support site) and its just stopped working and uninstalling and reinstalling makes no difference, then it could be the eg: "VPN server you are connecting to, and “you might need to try the different Nord VPN global servers”, as could be a VPN routing issue.
If you have tried all of the different global VPN Server connections, then you will need to contact Nord VPN support.
Thank you. I have trying to work it out with NordVPN but they don’t seem to have th correct answer. When you say uninstall/reinstall, do you mean emClient or Nord?
I mean try uninstalling and reinstalling Nord VPN.
If that doesn’t make any difference and Nord VPN support cannot fix it, then you might need to try a different VPN service.
Some users on this forum use eg: Open VPN or Surfshark which they say work fine “once configured correctly”, so you may want to check out those.
