Hi ,
after installation of my gmail account, evertyhing is OK
I can send mail BUT I don’ tsee mail in my mailbox.
Everyghting looks fine ( no error , no warning)
I was used the auto setup
I tryied manual setup - everuthing was OK but again no mail downloaded in the Inbox folder
I 've setup another mailbox (OVH provider) and everything is OK , Inbox is correclly filled
Any idea ?
THX
JP
On Gmail Check your “Settings” “Labels” Make sure they are selected as “SHOW”
including the " ALL MAIL" Label
oh my god, what a parameter ! all mail label was off , now it works !
Thanks a lot
JP
That items must be active but that one can be hidden from view on emclient if you find it annoying
On left move mouse to account name and right click and you get an option to hide or show items.
great .
just , THANKS a LOT !
JP
Please use the emclient backup facility as it works very well. It does not restore tailored themes
so copy your tailored theme to a safe place and your license and your install install program.
Enjoy
Hi , maybe you can help me again,
but only with gmail inbox, If I delete msg ( with DEL key) em Client flag it as “Trash” but don’t remove at all from the inbox
(with my OVH account, it works perfectly)
any idea ?
THX in advance
JP
check the settings in gmail “forward …”
Under the IMAP section
When I mark a message in IMAP as deleted:
Auto-Expunge on - Immediately update the server. (default)
Auto-Expunge off - Wait for the client to update the server.
When a message is marked as deleted and expunged from the last visible IMAP folder:
Archive the message (default)Move the message to the TrashImmediately
delete the message forever …
