Google Contacts (Gmail) has this category “Other Contacts”, which is actually the same like eMC “Recipient History”. Every contact i had a conversation with, will get collected in this category.
In Google contacts they are not actually saved contacts, just a history log (“Other Contacts”).
But what makes this so awesome is, that exactly this feature is responsible for the email address Auto-Completion feature. So it works while being in Gmail, but it does not work while working in eMC.
It’s because eMC has its own recipients history, which completely ignores the Google one.
Now this is really bad, because i have over 2000 of those in my Google “Other Contacts”, which i don’t want to add to my actual contacts. They are just for auto-completion.
But the only thing which eMC is syncing are actual Contacts or any Contact with a specific label/tag.
The problem is that this labels/tags will never sync, because Google will always “just” store them in “Other Contacts” and don’t give them automatic labels.
So why isn’t eMC either including the “Other Contacts” folder of Google Contacts into the program, so they can be used for auto completion or adds those Contacts directly to the in-buildt “Recipients History”?
I would love to buy a PRO License, but without this Feature i don’t see me doing it.
Thanks for help!
