despite all the efforts and advertising, yet I cannot find a program that really provides a true and full synchronization with Gmail contacts.
Just discovering now that just some fields are synced only partially, for ex. phone numbers are just two, that’s a sin… another failed attempt to make a Gmail contacts sync…
I’d like to discover why this is not possible … have a partial sync with Gmail contacts does not help nothing … or it syncs, or it does not!
Hi, not completely sure what you’re referring to, you can synchronize more phone numbers, but to switch the current displayed, you need to click on the phone number type and select another one if available. Or you can view all the phone numbers in custom/phone list view.
To do so just use the columns configuration and add the specific phone number type into the list of displayed columns.
It’s easy to understand, example: in Google contacts I’ve a contact with 5 phone numbers (mobile1, mobile2, work, home, work2). Ok? So, I open the contact in eM Client Contacts list and I see only two phone numbers (house, work).
Where are the other three phone numbers (mob1, mob2, work2)?
It’s easy, as I previously suggested, you have to click on the phone number type (e.g. house) and select another type of the phone that was not visible before (e.g. mob1). Or as I suggested configure your columns in the custom view to view all these phone numbers in the list of contacts.
Oh good, got it now. Ok, I switched to “Custom view” , now I can see all fields needed. Thanks.
Great, glad I could help, please make sure to let us know if you come across any future issues or questions about the application, we’ll be happy to help.
Paul
