I’ve set up Gmail no problems. The calendar has synced fine and I can send emails but no emails are being received.
In Gmail Settings check the following
Labels Make sure that “All Mail” is checked SHOW It is a requirement in version 7
and any other label that you want to see.
Emclient
Make sure your Import ports on emclient account is correct
Menu-tools-accounts look at import port for imap mine are 993 imap.gmail.com
SSL/TSL on special port (legacy)
That’s done the trick - many thanks for that.
