Very often, usually when moving the window “burns” the signature or an image as a “ghost-image” into the screen.
Only in the program “em-client”!
I had the problem on an old computer (weak graphic card)
Now, on a new computer the same problem.
The ghost-imagge disappears only when I turn off the screen several minutes, or when i restartthe system.
Thank you for contacting us. The problem that you report is known Internet Explorer bug and since eM Client uses IE core for messages displaying it affects eM Client as well. However, we are currently working on brand new version 7 which uses Webkit instead of the old IE core so the problem should no longer occur then. You can download V7 here: http://www.emclient.com/dist/v7.0.248…
-Dave
