We do not support IPv6 in any way. I even disabled IPv6 on windows level. Still Em Client tries to use IPv6. Please help me with advice.
I do NOT see any reference to iPv6 in your screenshot.
When you say you have disabled on Windows level presumably you refer to setting in Ethernet/WiFi properties.
Have you also checked your Router/Hub settings & rebooted the Router also OS?
Why are you using “Dr Web”?
Have you tried with anti-virus & firewall disabled?
As far as I am aware eMC would NOT by default call iPv6
Has eMC ever worked correctly or is something that has just started?
¡Buena suerte
skybat
¡Los mejores deseos desde Sevilla y mantente a salvo!
Please refer to the red highlights
No, I disabled IPv6 using registry keys
Yes, I’ve rebooted PC, no I did not reboot router
I like Dr Web. Is there a problem with this av?
No, and I don’t think I should. Reason being this error log from em client
---> System.InvalidOperationException: The operation is not allowed on non-connected sockets.
It clearly says that there is no net socket. This is so true considering IPv6 fully disabled
On my other laptop there is no such problem, but on my home PC there is. I dont know where to look to be honest
On my other laptop. Win10 machine as my PC.
domingo 23 abril 2023 :: 0907hrs (UTC +0100)
Я лично и по моему указанию моя компания больше не имеет никаких дел с какой-либо организацией или частным лицом, где есть какая-либо форма связи с Россией, какой бы незначительной она ни была.
¡Buena suerte!
Skybat
Будь ласка, підтримайте Україну будь-яким способом.
Слава Україні!
Смерть Путіну
