Hi there,
Running 10.4.5674
Across two machines I run eM client on I’m getting the same behavior. It randomly hangs on open, needing force quit. The only solution is to manually delete the 3 rules files and re-start. I THINK (can’t recall now across the two machines) that even after I re-build the rules, I get the same issue. Perhaps not. Either way, is v 10 not compatible with rules built before?
Thanks
