Forward as attachment not working
Program rejects .eml files. I see that this is part of an old problem.
I am using version 10.3.2622, and I have been unable to forward messages as attachment. Every time I try, I get this:
[SMTP] Cannot send message (Sending email “Beginning Prop Designer Search” failed with error: Email body not accepted due to the following reason:
"Attached file ‘Props For Loot.eml’ has disallowed extension.
Is there a fix? This is the first time I’ve considered dumping eM Client.
Email body not accepted due to the following reason: "Attached file ‘Props For Loot.eml’ has disallowed extension.
According to a Google search
Quote: The error “Attached file Props For Loot.eml has disallowed extension” indicates that the email system or server is blocking the sending or receiving of attachments with the .eml file extension. This is a common security measure implemented by many email providers and hosting services to prevent potential risks associated with .eml files.
So sounds like either your sending server or the receipients server is not allowing the .eml attachment if you are forwarding an eml attch
Came across this too, a couple of times. Just zip it, or whatever. Or maybe a feature for eMC: have it do the zip’ing?
