Fonts in To/CC/Subject
When I compose the email I found the fonts in To/CC/BCC/Subject are different from the body, and I can’t find where in the setting I can change this.
The subject name displaying at the top edge of the window as well, followed the font in the subject box.
The To/CC/Subject etc. are part of the message header where there is no formatting, so any formatting you did choose for those fields when composing the message would not follow with the sent message. It just depends on which font the UI uses as to how they are displayed.
You might want to look into editing themes in eM Client, if you want to change the way the UI is displayed on your computer, but I really don’t know if you can change the fonts for those things.
Tks Gary. That’s kind of weird I’m using the default theme only n didn’t change a thing, but the fonts in the to/subject field looks totally different *_*
They look different to what they did before?
I installed the program for not too long, and I think this is the first time I compose an email n I found out this issue.
B4 this, I mainly read emails only which have no problem at all.
