font not working
since 7.1 (also latest beta 2), the segoe ui semilight font is not working in email compose window.
see attached image
i’ve checked the generated html and it is missing the tag
segoe ui semilight:
Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet.
compared to segoe ui light (this works)
I just figured out whats really happening (beside of wrong rendering of Segoe Semilight).
The font you select in settings as default font for new emails will never be set as font face in the email!
So for example: if you pick Tahoma as for default font and you write a new email everything looks fine, but the font is not set in html code of the email. So the recipient will open the email and see it in for example Calibri or something else.
Please investigate this bug!
