Folder coloring is a great feature; however, as presently designed, it only allows user to color the outline of a folder, which means that it’s of limited value - the grey theme color prevents the folder from standing out as desired. A better design would be for the entire folder to be filled with that color.
You can vote for Solid Folder colours via the below Sleekplan Suggestion.
There is also an option to color entire folder name in Settings - General - Folders - Color
‘‘Use folder color for icon and text’’
That way the color will stand out more.
THANK YOU - that’s helpful!
