I have a subset of my folders which I commonly move items to, and which do not change through time. I ALWAYS want those in the Move to Folder dropdown, and always in the same position in the list. I often use other folders on a one-off basis. What is happening is the one-offs are replacing my desired folders and when I go to the menu, I have to regroup and use another method. This is unproductive and IMO counter intuitive. Please allow a selection of folders for the top of the menu list, and then, if you wish, fill the remainder of the space with however you currently select folders. Thanks!
