Favoriten fixieren / Pin favorites
Gibt es eine Möglichkeit, dass die Favorieten (Mail Bereich von eM Client) fixiert werden kann. Damit ich nicht immer nach oben scrollen muss, wenn ich die Ordner bein den eMail Accounts aufgeklappt habe?
Danke und freudliche Grüße,
Michael
Is there a way to pin the favorites (Mail section of eM Client) so that I don’t have to scroll up every time when I have expanded the folders in the email accounts?
Thank you and kind regards,
Michael
Pinned Favourites is a very handy feature in Outlook. I have hundreds of folders and I have to scroll up a mile to get back to my favourites.
If you right-click on a folder in the folder list (left hand side), a menu comes up and you can select “Add to Favorites.” Your Favorites folders will be listed at the very top of the panel. So, yes, eM Client has that feature too. :slightly_smiling_face:
You can also use key G shortcut, to go to a specific folder really quickly.
I badly want to switch from Outlook and I’ve been an Outlook user since 2008, but not having the ability to “dock” or “pin” the “Inboxes” or “Favorites” so it is always visible is absolutely brutal. I have 11+ email accounts and need to be able to scroll down to a folder within one of them but still be able to quickly jump to from one inbox to another via a docked Inboxes/Favorites. I don’t want to always have to scroll the left pane to the top to see what new email has came into my inboxes. I may be working specifically in a folder within a single email box.
Please please please prioritize this feature request because for power users, it is so difficult to always be scrolling within eM Client and it’s the biggest hold-up for me making the switch.
There is a Sleekplan suggestion to pin Favourites which you can vote for below.
See also @Michal_Burger comment on this topic in another thread.
