I am trying to get EM Client to Sync my FastMail Calendar without much success, when I look at the CardDAV Log file I have the errors below error messages
According to FastMails Help, the following is required:
Server = https://caldav.messagingengine.com/
SSL/TLS Encryption = Yes (required)
Username = Your FastMail email address, including the domain
Password = Your FastMail password
I have the right account in Fastmail for this service and I use this without problems with Mail on OSX, so I can only assume I need to make some thought of setting change in EM.
Thanks,
Gavin,
12:42:08.507|022| C: OptionsCommand https://caldav.messagingengine.com/
12:42:08.850|022| S: OPTIONS https://caldav.messagingengine.com/
12:42:08.850|022| NotFound Not Found
12:42:08.850|022| Response, stream length:
-1, 162
12:42:08.850|022| Content:
12:42:08.850|022|
404 Not Found12:42:08.850|022|
12:42:08.850|022|
404 Not Found
12:42:08.850|022|
nginx
12:42:08.850|022|
12:42:08.850|022|
12:42:08.850|022|
12:42:08.850|022| C: PropfindCommand https://caldav.messagingengine.com/
12:42:08.850|022| <?xml version="1.0" encoding="utf-8"?>
12:42:08.944|022| S: PROPFIND https://caldav.messagingengine.com/
12:42:08.944|022| NotFound Not Found
12:42:08.944|022| Response, stream length:
-1, 162
12:42:08.944|022| Content:
12:42:08.944|022| 404 Not Found
12:42:08.944|022|
12:42:08.944|022|
404 Not Found
12:42:08.944|022|
nginx
12:42:08.944|022|
12:42:08.944|022|
12:42:08.944|022|
12:42:08.944|022| C: PrincipalMatchCommand https://caldav.messagingengine.com/
12:42:08.944|022| <?xml version="1.0" encoding="utf-8"?>http://icewarp.com/ns/"; />http://icewarp.com/ns/"; />http://icewarp.com/ns/"; />
12:42:09.179|022| S: REPORT https://caldav.messagingengine.com/
12:42:09.179|022| NotFound Not Found
12:42:09.179|022| Response, stream length:
-1, 162
12:42:09.179|022| Content:
12:42:09.179|022| 404 Not Found
12:42:09.179|022|
12:42:09.179|022|
404 Not Found
12:42:09.179|022|
nginx
12:42:09.179|022|
12:42:09.179|022|
12:42:09.179|022|
12:42:09.179|022| C: OptionsCommand https://caldav.messagingengine.com/
12:42:09.272|022| S: OPTIONS https://caldav.messagingengine.com/
12:42:09.272|022| NotFound Not Found
12:42:09.272|022| Response, stream length:
-1, 162
12:42:09.272|022| Content:
12:42:09.272|022| 404 Not Found
12:42:09.272|022|
12:42:09.272|022|
404 Not Found
12:42:09.272|022|
nginx
12:42:09.272|022|
12:42:09.272|022|
12:42:09.272|022|
12:42:09.272|022| SynchronizeFoldersCommand executing on ( /ACCOUNT:5)
12:42:09.272|022| C: PropfindCommand https://caldav.messagingengine.com/
12:42:09.272|022| <?xml version="1.0" encoding="utf-8"?>http://calendarserver.org/ns/"; />http://apple.com/ns/ical/"; />
12:42:09.366|022| S: PROPFIND https://caldav.messagingengine.com/
12:42:09.366|022| NotFound Not Found
12:42:09.366|022| Response, stream length:
-1, 162
12:42:09.366|022| Content:
12:42:09.366|022| 404 Not Found
12:42:09.366|022|
12:42:09.366|022|
404 Not Found
12:42:09.366|022|
nginx
12:42:09.366|022|
12:42:09.366|022|
12:42:09.366|022|
12:42:09.366|022| SynchronizeFoldersCommand finished on ( /ACCOUNT:5)
