Exporting from Incredimail to eMclient
I have been using Incredimail for email. I would like to import my contacts and folders into eM Client. Can this be done? Incredimail doesn’t show up on the standard list of email services when I go to “import” via emclient.
import from Incredimail is just partially supported. You should be able to export the contacts into a format that’s supported by eM Client. Or you could do a workaround and import into Thunderbird and use the import from Thunderbird.
However direct import from Incredimail is currently not supported.
I hope you understand,
Thank you.
