Why aren’t all the settings in the File -> Export -> Export Settings?
I know that it works using using the backup and restore function as well.
Hi, what do you mean by all settings?
Exporting settings into .xml file, only exports your account settings including your password if selected, but not the settings of the application, for that you have to use the backup.
Thank you for understanding,
Hi Paul,
Ok, thank you for your quick reply. Using the backup did the thing.
But in this case the function should better be called import/export “account settings”, don’t you think so?
Kind regards,
Dirk
Hi again Dirk, it might be more clearer yes, I’ll notify the developers about this issue, if they’d like to consider improving this in future releases.
