I’ve been able (until recently) to export events to a remote hard drive. Now it gives me a error message. An error occurred when saving items. Saving to file “Z:\scheduled items.ics” failed with error “The added or subtracted value results in an Parameter name: t”. The only change is that I’ve upgraded to Windows 10. Thanks for any help.
Hello, can you please try to update to this release, and check if the issue persists? http://www.emclient.com/dist/v6.0.23330/setup.msi
If it does, can you please try to perform a folder repair on your calendar folder that seems to be having issues with the calendar item (specified in the error), to do so, right click the folder in the left pane and navigate to Properties > Repair and perform repair by clicking the button.
The update solved my problem. Thank you, Paul!!!
Glad it works, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
