Exchange distribution list does not contain contact
Hello,We are currently testing your eM Client solution to replace our Outlook connected to an exchange.We are currently experiencing a small problem, the distribution lists contain no members.It is therefore impossible to send an email to these lists.Thank you in advance for your response.
In exchange :
Hello, we’d like to take a closer look at what’s causing this. Are the affected distribution lists part of a global address list, or are they saved directly in your Exchange account?
Hello Kim,
Ours lists are global lists configured in ECP → recipients → groups
Group type is distribution group.
Thank you for the details and for bringing this to our attention. Unfortunately, resolving this is likely to take some time, so we’re expecting a timeline of weeks rather than days, but we’ll start investigating the issue and keep you informed of any progress. I apologize for any inconvenience this may cause in the meantime.
Hello Kim,
Thank you for your feedback, I imagine this will not be easy.
We will continue testing the application because this test aims to verify that we could no longer use Outlook in our municipal administration. Best regards.
The conclusion is that unfortunately, OAB doesn’t support this functionality, and we aren’t planning to add to add it via EWS calls, given that OAB is only supported on on-premises EWS and doesn’t work on M365 anyway.
In the future, we’ll need to transition to a different protocol and we’ll revisit this then. For now, our team will implement a small adjustment so that you can at least send emails to these distribution lists.
I’m sorry for the inconvenience.
Hi Kim,
Thank you for your response.
I completely understand.
Best regards.
