Has anyone else noticed EM Client thrashing exchange web services? We have recorded the EM Client doing EWS requests doing things like 80+ EWS requests in 2 seconds, and occurring every 10 minutes or so.
Example:
15:18:37–15:18:39 — roughly 60 EWS requests in 2 seconds
15:28:37–15:28:39 — another 80+ EWS requests in 2 seconds
15:37:36–15:37:57 — another 50+ EWS requests
15:38:37–15:38:39 — another 80+ requests
545 total EWS requests in the 45-minute window, all returning 200
Hello, the 10-minute interval corresponds to our default synchronization interval.
If you’d like to synchronize less frequently, you can increase this interval in Settings > General > Synchronization under Synchronize items every x minutes.
Try setting it to 20 minutes, for example, and see if that improves the behavior.
This periodic synchronization usually checks all folders, so depending on your account, the number of requests may be consistent with the amount of data. We’d need to see the full EWS log to confirm. Since EWS synchronizes everything (emails, calendars, contacts, notes, etc.), it is a fairly chatty protocol.
You can enable logs for the account in Settings>Advanced and then find them via Help>Open Logs Directory. You can check the log in a text editor or send it to [email protected]
