attempt to connect to igmail failed. Keep getting this message. Even thou initially sync’s OK. Also, I NEVER set up the Account name as iGmail. Wouldn’t have seen a reason for, since I, at this time, can’t think of one now. So how’d that happen?
Hi, since when are you receiving this issue? Was it working properly before or are you having the issue since you setup the account?
Did you use the automatic setup for that account?
I’m having the same issue…
Hi Stephen, can you please answer the few questions mentioned above as well? It would help me identifying the issue.
Hi Paul
Appreciate the support. Is there a way I can contact you directly please?
Cheers
Stephen
Hi, we usually take care of the free license user issues and questions here on the forum. By purchasing the pro license you’re entitled to a priority direct support.
Thank you for understanding,
Hi Paul
NP… The only reason I asked was that I was going to try and work closer with you in regards to trouble shooting this issue.
Cheers
Stephen
