" [XMPP]Object reference not set to an instance of an object.Object reference not set to an instance of an object."
Any know what this means and what can be done to fix this from popping up? Semding and receiving email still works fine but this keeps popping up as an error? I see in the past this has been posted but there are no solutions that I can see.
Thanks for the reply. I followed the instructions however there is no “XMPP” to untick? Not a problem I will continue to ignore the error and allow the developers to handle in the upcoming versions.
Thanks as always for the quick reply and stay safe!
