I had problems with my computer cables yesterday, now my emclient will not open.
error message says
database verification and repairing failed
error message says
Without seeing the details it is unclear what the issue is, but this usually means that the database is heavily corrupted so there are few options.
Some users have found that restarting Windows, or restarting eM Client a few times resolves the issue, but otherwise:
If you have a recent backup, you can delete the current eM Client database, then restore the backup and eM Client should start working again without any problems.
If you don’t have a backup, but all your data is synced with servers, then you can delete the database and start over. After adding your accounts, eM Client will resync with the server.
By default, the database is the C:\Users\yourusername\AppData\Roaming\eM Client\ folder. You may have to enable hidden items in Windows Explorer to get there.
