[IMAP] Failed to LIST server folders ( LIST Server error - Please try again later)
keep getting this error .. How do I fix it?
That normally means your IMAP mail server is either “not online currently” or “has some technical issues at the server end”, which usually automatically fixes itself when that’s resolved.
Go online to your webmail and see if your mail folders are all showing and reading ok.
Also check with your mail server technical support via phone or website to see if there is any current problems with connecting mail clients today.
If you can see and read all the mail folders ok online, and your mail server technical support say their end is ok and closing and reopening eM Client makes no difference, then suggest you go to “Menu / Accounts” and remove and re-add your account and see if that fixes it.
Note: if you do try removing and readding your account, make a backup first via “Menu / Backup” incase you need to restore for any reason.
