By the way, why has this topic been flagged as solved?
because it should be resolved in newest versions (corresponding date of my last post).
Year has nothing to do with bugs, programming is way too hard in matter of predicting unsusspected actions - that is why issues and bugs still exist.
Anyway do you still have this issue in newest version http://www.emclient.com/dist/v6.0.197… ?
Jan
eMClient still has problems with GMAIL running IMAP. No problem doing the same with POSTBOX. Would switch entirely to eMclient if this was fixed but I cannot afford to lose or have a long delay in getting updated email. Your contact list is still the best and I use it in conjunction with Postbox.
eM Client’s Gmail support is best from all existing email clients, together will simple interface and fast database it is our main feature around it is designed.
Can I ask you what problems exactly do you have? For example what is written in your error messages?
Jan
Here is the popup box that shows the error. There is no problem in POSTBOX getting this message or my samsung android mail, but this error happens frequently with eM Client.
The program recently updated to version 6.0.19714.0. It offers no further update when I click “check for updates”.
i just redownloaded the client and have the same problem, so the version that is on your page right now is the exact version. I’m using naver.com, and I’ve tried both imap and pop3 and both give the same error. In any case, I only have 3 days left on my trial and don’t want to pay for three email addresses using a broken app, so I’ll have to look elsewhere; thanks
Go to Tools - Settings - General - General and uncheck “show window when an error message occurs”.
JAn
