HELP!!
this is a server sided issue. Does the problem still persist? If so, can you try to login to the account in a browser?
Yes the problem is still there. Are you going to be able to correct it?
I receive hot mail OK, but I can’t send anything.
Yes I know that I can log into the browser.
This is really most likely server sided issue, but for us to be sure can you send me SMTP logs?
Tools - Settings - Advanced, check STMP under your account, apply and restart eM Client.
Then simulate steps which leads to your issue and after send logs… to [email protected] together with this topic’s URL.
then you can turn logging off
regards
Jan
