If you add your account by going to Menu > Accounts > Add Account and enter your address in the automatic setup, it will setup the account correctly. And you need to do that with Microsoft free accounts like MSN since they disabled basic authentication. Microsoft accounts now require oAuth, which can only be enabled using the automatic setup.
For free MS accounts we don’t use SMTP because Microsoft broke their implementation of oAuth on SMTP. Instead we use AirSync to send messages.
So something you can check is to go to Menu > Accounts and click on the General tab for the account. Scroll down to Services and make sure the AirSync option is ticked, then click on Save & Close and try send a message.
4:15:11 PM Msn [IMAP] MailClient.Accounts.ConnectionException: Failed opening connection to server.
—> System.IO.IOException: No server response within 30 second timeout.
at MailClient.Imap.Base.Connection.ConnectAsync(Func`2 getStream, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken)
— End of inner exception stack trace —
at MailClient.Protocols.Imap.ConnectionPool.AcquireConnectionAsync(Folder mailFolder, Boolean noSelect)
at MailClient.Protocols.Imap.ConnectionContext.CreateContextAsync(ImapAccount account)
at MailClient.Protocols.Imap.ImapFolderSynchronizer.ListFoldersAsync(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapFolderSynchronizer.GetFolderList(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken)
at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass16_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass11_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct)
at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status)
at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status)
at MailClient.Storage.Synchronization.FolderSynchronizerExtensions.SynchronizeSubfoldersAsync(IFolderSynchronizer synchronizer, Folder folder, SynchronizationPriority priority, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapAccount.SynchronizeIntAsync(Boolean forced)
at MailClient.Protocols.Common.SynchronizableMailAccount.<>c__DisplayClass7_0.<b__0>d.MoveNext()
IMAP_SERVER_TYPE = Outlook
EnqueuedStackTrace =
at MailClient.Protocols.Common.FolderSynchronizer.GoOnlinePre()
at MailClient.Protocols.Imap.ImapFolderSynchronizer.GoOnlinePre()
at MailClient.Protocols.Imap.ImapAccount.GoOnlineInt()
at MailClient.Protocols.Common.AccountBase.ChangeOnlineState(Boolean online, OfflineReason offlineReason)
at MailClient.Protocols.Common.AccountBase.GoOnline()
at MailClient.Protocols.Imap.ImapOptionsControl.Close(DialogResult result)
at MailClient.Accounts.Mail.MailOptionsControl.Close(DialogResult result)
at MailClient.UI.Forms.formAccounts.formAccounts_FormClosing(Object sender, FormClosingEventArgs e)
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at MailClient.Common.UI.Forms.ThemeForm.WndProc(Message& m)
at MailClient.Common.UI.Forms.BorderlessForm.WndProc(Message& m)
at MailClient.UI.Forms.BorderlessBaseFormWithToolbar.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
at Interop.User32.SendMessageW(IntPtr hWnd, WM Msg, IntPtr wParam, IntPtr lParam)
at Interop.User32.SendMessageW(IHandle hWnd, WM Msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Form.Close()
at MailClient.UI.Forms.formAccounts.stripButton_ActionButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.PerformClick()
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at MailClient.Common.UI.Controls.NonFlickeringUserControl.WndProc(Message& m)
at MailClient.Common.UI.Controls.AutomationViewUserControl.WndProc(Message& m)
at Interop.User32.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.Interop.Mso.IMsoComponentManager.FPushMessageLoop(UIntPtr dwComponentID, msoloop uReason, Void* pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(msoloop reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(msoloop reason, ApplicationContext context)
at MailClient.Program.<>c.b__185_3()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m)
at Xilium.CefGlue.Interop.libcef.run_message_loop()
at MailClient.Program.Main(String[] args)
