Enable automatic theme switching for Discourse
Unless I missed it, I don’t see the option in the forum settings to enable automatic switching for the theme from light to dark (and vice versa) which has been a natively supported feature in Discourse for a number of years now.
Thank you for this feedback! I have now set up a Dark theme for our forum, so hopefully it should work as defined in the Discourse article :slight_smile:
I think it’s working now. I think you can now disable/remove the option for users to switch themes as that was confusing me for a bit, as it is now redundant. From what I recall, I think the old way of automatically switching was to use a module to switch the theme. But now I guess themes are more used for larger visual changes while the colour palate is an addition to that light/dark toggle.
This is great and i was unaware of it. :slight_smile:
It would be great to have a switch similar to the one we have in the UI of eM Client so it would be easier to discover it and find it, it´s kind of buried to find this setting today in this forum.
